Crosshairs for Advanced Output
yochee
Post by yochee »
Crosshairs for Advanced Output with enable/disable button
(might be helpful if the cursor is lost on the big screens)
Empyfree
Re: Crosshairs for Advanced Output
Post by Empyfree »
This already exists (kind of)
https://resolume.com/manual/en/r5/outputtransformation
Scroll down and check out the bit entitled Show Grid.
You have to turn this on and off per slice. But it's still useful.
Well, actually, you don't have to toggle this for every slice. You toggle it once, and then every selected slice will show its outline and a grid. And of course crosshairs.
Empyfree
Post by Empyfree »
Have you been logging into my webcam... that's a surprisingly good caricature of me...
Apologies for the mis-info. I only generally use the feature when using projectors, and since we got LED wall I hardly ever use projectors any more.
yochee
Post by yochee »
oh, ohkey, I never use the grid :D
