So I'm trying to figure which RGB Pixel controller to go with and I'm now deciding between the F16v3 or PixLite 16 MkII? They are similarly priced and have simliar functionaliy. The F16v3 has Wifi which could be super helpful while the pixlite mk II has more DMX (RS-485)outputs.
Here is the comparison chart which makes little sense to me because I'm a noob and this is the first time I will be working with LEDs pretty much.
http://nutcracker123.com/nutcracker/rgb_controllers/
What are your thoughts?
Which RGB Pixel controllers would you go with, the F16v3 or PixLite 16 MkII?
blabberbytes
blabberbytes
Re: Which RGB Pixel controllers would you go with, the F16v3 or PixLite 16 MkII?
Have you tried the F16v3? How is the pixlite16 mk2 better than the F16v3?
Never use WiFi – unless you are working for free and/or don't mind risking your reputation.
Go with the PixLite. Have used dozens of them, and they have never failed me. Super reliable, super intuitive web interface to work with. I wouldn't go with any other controller at this point.
