Magewell PRO series support
madido
Post by madido »
Hello,
Is Magewell PRO series SDK 3.0 supported in Arena?
Reading from Magewell's FAQ using the 3.0 SDK, latency can be as low as 1ms at 1080p 60 YUV2 !!
And what about Output from Magewell cards? (SDI)
Thank you
Stefano
Re: Magewell PRO series support
The moment Magewell brings out an SDK that works with all their cards on both OSX and Windows, we'll be happy to write support for it.
As it is, their SDK changes every 6 months. Last we checked with them, the current version only supports the Pro series. Which means it works with the new internal cards, but not with the external boxes that everyone uses.
We can't work with an SDK that only works with half of their devices.
Warspite
Post by Warspite »
By the way, how it is going with AJA USB solutions?
Can we hope for lower latency? :)
Amazing things are about to happen ;)
Warspite
Post by Warspite »
Hooray! Hooray!
