Unwrap distorted video from parabolic mirrors
Riser
Post by Riser »
I am looking for software to un distort live video shot using a 360 degree parabolic mirror. It is early days but I have found a basic formulae for the distortion which should allow me to create a cylindrical image format used in head mounted displays. In principle it should be no different from say wrapping live video around a sphere or onto any other geometric object. Any advice or sources of information would be much appreciated.
Regards
DAS BEN
Post by DAS BEN »
if you want to do live 3d stuff, try pilgrim, whre you can create complete 3d scenes in 3d. but this kind of vj-software, you have to programm your sets much more, it is not so intuitive, as resolume.
levon
Post by levon »
from what i think you are trying to do, you might want to check out a program called HDRI shop, its used for High Dynamic Range Images, and can be used for polar coordanate maping and what not.
