crash! :(
olim
Post by olim »
Hi guys,
This is my report after 3 gigs in last week in total of 24 houers playing with reso 2.2:
1- All times, when a open reso, show me a mensage saying that “can´t open the aplication beacuse can’t found the xvidcore.ddl”, but i give 2 times OK in mensage and reso opens whithout any problem. I have reinstaled rerso aplication and i still with this mensage (any sugestion?)
2- when i load some video files to reso deck, they crash. I don´t now why, because i use the same codec (indeo 5.1) to all videos, and this problem just happen whith some of them. Some swf files crash reso as well. (i send you that files). For this situation i found a solution: i load all video files in reso 1.5 and save deck in reso 2.2 deck folder. In this case, i can load decks in reso 2.2 and play the same clips that crashed before when i loaded that clips to deck in reso 2.2. This its strange because i can play the videos if they are saved in a deck of reso 1.5 but i can´t load that files alones in reso 2.2. one more thing: the files that crash in reso 2.2 in a preview still image have a vertical bar in right side of that image. Hope that it help.
3- The RGB channel select on layers and effects are a great idea. ;-) realy enjoy it!!!!
4- Can you put in a next version playmodes with control playback speed and directios (like have to video files) in opacity channels (masks, transitions and overlay channels) ?! I think that is will give more improvise to the mixes.
My laptop:
AMD 2500+ with winXP home edition and SP2
512 mb ram
ATI 9600 with 64 mb
AVI 320x240 and 384x288 Indeo 5.1 codec
So think that all and hope that my report helps you,
Keep working guys, you are doing a great job.
Hugs,
Olim (chiklet tv)
P.S: in my output sreen, i have a black border around the images. (I have the last ati omega drivers recomended in this forum by bart). This is happen with all ati 9600 graphic card or i have made a any mistake?! Any sugestion?
