Hi!
On my computer there are 2 NVS 810 video cards with a total of 16 outputs. However, the Arena Resolum sees only 8 outputs. How to fix this problem. It is present in both Windows and Mac OS X.
More then 8 out
Re: More then 8 out
Does your computer see all 16?
sharapov_f
Re: More then 8 out
Yes. And MadMapper see 16 out to.
Re: More then 8 out
Interesting. What does the list under Output > Fullscreen look like?
sharapov_f
Re: More then 8 out
There are outputs from 1 to 8 and Decklink device
Re: More then 8 out
So when you said you see 16. Where do you see 16?
Re: More then 8 out
Do you have 16 actual outputs connected to your 2 NVS 810 cards?
Also, you mention in your first post that you see the 16 outputs on Mac OS X, do you have your 2 NVS 810 cards on a Mac Pro or are you using a Hackintosh?
sharapov_f
Re: More then 8 out
Yes, i have 16 actual outputs connected to your 2 NVS 810 cards on my Hakintosh
Re: More then 8 out
Could you post some screenshots of your display setup in Windows and of the Fullscreen list in Resolume?
