hi all
Im looking to build or buy an machine to run 18 hour days running different content across 12 different room in a nightclub/restaurant/bar with 25 1080/4k screens in total & but all content will be 1080p.
we have a 16 channel output switch with 12 input to do most of the routing with also 4 sky box's and standerd free view tv also mixed in
but i need a system what can run resolume with at least 8 layers as 8 or more outputs or even a setup of GPU's what can do the job
i have been looking a a dual set of gtx 1080s and i7 with 32gb ram and or a triple head to go if theres not enough outputs on gpus
if theres any other option please let me know
thanks
new build 8+ layers 8+ outputs HELP
liam gillespie
TOURING VJ - PC SPECIALIST OCTANE VI LAPTOP
I9 - RTX 2080 - 32GB RAM - 2TB SSD
TRAKTOR X1 - TRAKTOR F1
ARENA 6 - NOTCH
Macbook Pro - Showkontrol Live
ARENA 6 - NOTCH
Re: new build 8+ layers 8+ outputs HELP
How many different pieces of content will be outputting? Just 8?
Will it need to be in sync with anything?
If it's just 8 and doesn't have to be in perfect sync, Try a black magic decklink quad with 8 sdi outputs into a sdi matrix and have that do your routing. use a single gtx 1080ti for rendering.
one Nvidia 1080ti + two Datapath FX4 and you can get 8 @ 1080p60 from two DP outputs.
Keep the HDMI for UI and you'll have one spare DP output for future expansion such as a third Datapath FX4 for an add'l 4 @ 1080p60.
