How would you build this with arena? plz help
Navnath
Post by Navnath »
Hii can anyone advise me as to what a proper setup for something like this would look like?
plz help me
Re: How would you build this with arena? plz help
I see that no one has advised you as of yet so I'll give you a few pointers:
  • - A lot of what you're seeing can be created in the advanced output setup.
    - If your composition is wider than one projector, first you'll have to blend 2 or more projectors to get a seamless image
    - Then, you'll create all the slices you need to break the artwork into all these segments.
    • - Pay close attention to how you line up any of the slices that will overlap screens.
      - Also note that any slice that you want to use for line animation and content will have to be duplicated and have different sources such as (layer 1 for lines and composition for content)
    - Export an SVG file an create line animation.
    - Import your media/content or stream it via Syphon/Spout/NDI
    - Voila.
