Show pc game as output from resolume
Hi! im trying to use a pc game as a clip in resolume, y wanted to play supermario specifically and add some effects to it, or at least being able to reduce the proportion of the output of the projector (like i do in resolume, but maybe there is some other program to do just this?) , but i dont know if its possible, not sure if spout works for it, tonight im going to try spout, but since im short of time maybe someone could give me some advice....
Re: Show pc game as output from resolume
SOMEONE ANSWER MEEEEEEEEEE
Welcome to the forum!
Just a reminder this is a user forum which means you need to be patient if you have a question and you haven't heard from anyone the next day
We all have jobs and other things to do so using capital letters which typically expresses frustration is not the best way to get peoples attention.
I do this at every festival I work.
I play nes, snes, and rocket league.
turn on NDI scan converter, add NDI source in resolume and play the source. Then go back to your game and play it.
or play it on another computer / console and output that into an input card, add input card as source into resolume
add also an NDI to Spout bridge (syphon on mac) as you can't use NDI directly on Resolume 5.dinga wrote: add NDI source in resolume and play the source.
Correctravensc wrote:add also an NDI to Spout bridge (syphon on mac) as you can't use NDI directly on Resolume 5.dinga wrote: add NDI source in resolume and play the source.
Sorry for the delay, im trying to do everything from the same computer, open the game in this same computer and show it as an output on resolumeArvol wrote:I do this at every festival I work.
In a pinch you could always use a headless video adapter on your computer to play your game on a virtual screen and pick it up in NDI scan converter.
