OUTPUT DISPLAY 2 NOT FUNCTIONING
parsedsa
Post by parsedsa »
okay , I've got resolume arena 5 running on windows 10 with following config
NVIDIA GEFORCE GTX 1060
core i7-7700HQ
cpu @ 2.80
16 RAM
DirectX 12
when I connect the second display via HDMI and set output to second screen , resolume CRASHES and starts NOT_RESPONDING
I've tried changing Nvidia settings and it didn't work
PLZ HELP
IT'S ESSENTIAL
THANKS
Re: OUTPUT DISPLAY 2 NOT FUNCTIONING
Are you running an Asus or MSI machine?
parsedsa
Post by parsedsa »
Joris wrote:Are you running an Asus or MSI machine?
Asus
Cool. In that case disable Sonic Suite and you're all good.
parsedsa
Post by parsedsa »
Joris wrote:Cool. In that case disable Sonic Suite and you're all good.
thanks a lot man, just saved my day:))))
I uninstalled the Sonic suit,
will I experience any troubles later for not having it on my system in general?
Nope.
parsedsa
Post by parsedsa »
Joris wrote:Nope.
thanks for your help :)
kunwardeep
Post by kunwardeep »
Hi Joris,
i am facing the same issue with my asus rog g701vi, i have tried doing everything. Updated all my drivers, uninstalled sonic suite etc, but still the problem remains the same. I bought this laptop last week because of nye gig and this isn't working at all. Please help
valh04
Post by valh04 »
did you have the solution for MSI ?
thank
valh04 wrote: Wed Apr 17, 2019 01:03 did you have the solution for MSI ?
Try uninstalling Nahimic and installing the latest nvidia drivers.
