12x 360° Pixel Ball String
(Length: 1,95m / 12 Balls with RGB LED each String / In & OUT Connector / Pixelpitch 150mm / Ball Diameter 40mm / 8,4 W / 1 String = 36 DMX Channels / Auto DMX Adressing)
1x Power Supply with 8 Outputs (max. 320W)
6x 5m Connection Cable
8x T-Adapter
4x DMX Adapter
4x DMX Terminator
_______________________________________________________________________
Set of RGB LED Bars for Sale - DMX Control - works perfects with Resolume >>> 1650,00 Euro zzgl. 19% Mwst.
24x LED RGB Bar (Length: 1m, Alu, black / 60 RGB SMD5050 LEDs / 16,2W / 20 Pixel > 60 DMX Channel / Auto DMX Adressing) with Clipholder
16x Trussholder with Halfcoupler
8x 5m Connection Cable
8x T-Adapter
4x DMX Adapter
4x DMX Terminator
Cabling & power supply of both Systems are identical and everything can be combined. Package Deal for both Systems >>> 2365,00 Euro zzgl. 19% Mwst.
The system can be viewed, tested and collected in Germany. Shipping is also possible for an extra charge.
Contact >>> info@trickboxx.net
