[fixed] browsing
1mpar
[fixed] browsing
Post by 1mpar »
I´ve got a problem with the browsing window. It displays the files in cronological order, not alphabetic. This turns thing difficult when there are many files in one folder.
Is there a way to change this configuration?
Despite this "problem" the v.2.2 is running very very very well :)
I played last saturday for 6 hours with 3 layer 3 fx a midi controller and an audio input and the result was just great!
Congratulations Bart & Edwin : )
1mpar
[Edited on 17-10-2005 by bart]
bryandod
Post by bryandod »
i'm having the same problem. weird?
bryan
Anonymous
Post by Anonymous »
i have the same problem. I asked for a solution before. The files on my C disk are ok, but any other partitions or external drives are not displayed alphabetically :(
could you guys tell me what file system you are using? NTFS or FAT? on what windows version and what language?
homing
Post by homing »
I'm having the same problem. I'm using fat 32 on windows XP (5.1 build 2600) original service pack.
It's an english version but i'm using a french keyboard.
I've been having this problem for every version of the version 2 (beta, 2.1 , 2.2) This problem is not present in the version 1.5
I've just reinstalled windows thinking i would solve the problem. But no
[Edited on 14-5-2005 by homing]
Anonymous
Post by Anonymous »
I formated my laptop and installed win xp professional with NTFS and now it´s working fine. The problem so is either with home edition or NTFS.
1mpar
Anonymous
Post by Anonymous »
I dont think that the problem is the home edition. Because i'm using prof. edition.
Hum but the question is... My vj windows is on one partition and my vj material is a other one. Is it the windows that i should format in ntfs or my vj material?!!
I guess we are not a lot more advanced!!
I think i'll try reinstalling windows with ntfs.
homing
Post by homing »
By the way that last post was by me. I forgot to logon
homing
Post by homing »
YAY! File browsing is now listed alphabeticaly! It was a Fat 32 bug.
I converted my 2 partitions (OS and vj files) from fat 32 to NTFS using partition magic and it now works!
thanks for the tip 1mpar . I confirm that it's a fat 32 bug.
Anonymous
Post by Anonymous »
I had the same problem and solved it converting my hg to ntfs
thank you
