Additional MIDI Output Color Maps
With V6 out now and the options for MIDI output velocity for color feedback on our controllers, I wanted to submit a color map I created for the MIDI Fighter Twister.
I'm hoping once all the bugs get worked out of the Beta, a few months down the road, We can start submitting, testing, and confirming hardware color maps for future updates, so we can get a nice pretty GUI of colors when selecting our output velocities (Just like the APC40 currently has, built into V6).
Here's one I created for the MIDI Fighter Twister:
If anyone else would like to start making these for your controllers, I think this could be a very useful tool for other users to reference when programming their controllers.
Also, If anyone would like to test and confirm this map, I would love some feedback on it as well.
Thanks.
Download Link:
https://www.dropbox.com/s/vjtithm623xa2 ... p.jpg?dl=0
Re: Additional MIDI Output Color Maps
So does this chart mean there's a linear interpolation between cyani-ish on velocity 18 to dark green on velocity 32? So every velocity has a slightly different shade?
Or does it do the same shade of cyan between 18-32?
Joris wrote:So does this chart mean there's a linear interpolation between cyani-ish on velocity 18 to dark green on velocity 32? So every velocity has a slightly different shade?
Correct on the linear interpolation. It slightly changes for each value. It mixes RGB values slightly differently for each value.
Foresight
Post by Foresight »
I haven't created a table such as yours but for the midi fighter Spectra the values are as follows:
0 - Bright Blue
1-12 - Off
13-18 - Bright Red
19-24 - Dark Red
25-30 - Bright Orange
31-36 - Dark Orange
37-42 - Bright Yellow
43-48 - Dark Yellow
49-66 - Bright Green (With slight hue shift from lower to higher values)
67-72 - Dark green
73-90 - Bright Blue (With slight hue shift from lower to higher values)
91-96 - Dark Blue
97-102 - Bright Purple
103-108 - Dark Purple
109-114 - Bright Pink
115-120 - Dark Pink
102-127 - White
The bright/dark refers to the brightness of the LED not to the colour.
Hope this saves someone else a bit of time!
"The earth without art is just eh"
Nocturnal.nz
Fantastic!! Thank you so much for sharing :)
