Resolume 5.1.4 no response
lovezhiqi123
Post by lovezhiqi123 »
system:Windows 10 1703
Resolume no response error sometimes~!
I don't know what is going on~!
Log file
Resolume Arena 5 log.zip
(7.44 KiB) Downloaded 595 times
francoe
Re: Resolume 5.1.4 no response
Post by francoe »
Don't know what's happening there, but...
Can you try to delete preferences and move your composition out of his folder so resolume starts with a blank one?
I tell you this because your log have just one repeated error:
Code: Select all
Failed to open file with VFW, try use Quicktime as fallback.
I don't know how it works, but that line makes me think you are trying to load a composition with files that needs some vfw decoder not present, and quicktime can't manage it either.
Can you give some context? I see you run it succesfully and quit at least one time. Is a new system? Are the needed coceds installed? Are you trying to run it over wine or something like that?
francoe
Post by francoe »
Oh, and what you mean with 'no response'?
what file formats are you using?
lovezhiqi123
ravensc wrote:what file formats are you using?
MOV DXV 3.0
lovezhiqi123
francoe wrote:Oh, and what you mean with 'no response'?
Resolume stuck,Can't do anything!
what are you doing in resolume when the issue appears?
can you upload one of the files that may show the problem?
thanks!
francoe
Post by francoe »
MOV DXV 3.0
In that case, is at least a little bit strange to see all those call to videoforwindows, right?
lovezhiqi123
ravensc wrote:what are you doing in resolume when the issue appears?
thanks!
When it stucks again,I will print screen!
lovezhiqi123
Zoltán wrote:what are you doing in resolume when the issue appears?
thanks!
