All my avi's, mov's and especially swf's pixelate quite substantially using Resolume. Is there something I am doing wrong, or is this a feature of the program?
My files are good quality and play at a decent res, in other players.
pixelation
The clips are various resolutions . A number were made in Final Cut/Premier using dvd quality images. Still pix at 300 dpi right down to 72dpi. Also, the flash files are using vectors, so theoretically their res should stay the same I thought.
I didn't know there was a resolution option to process in Resolume. What's that about?!
Thanks for replying. I have a big show this weekend and am trying to make it as high qual as possible.
check the process and output resolutions option and bit depth under screen setup...
just a brief info, pal means 720 * 576 so, if your process/output res. set to 320 x 240 lets say, it is almost quarter of the pal video size which means, it enlarges and loose the quality 4 times...
hope that helps
bw
t.
[Edited on 11-4-2005 by MtB]
hope that helps
bw
t.
