Arena6 composition not loading
tonreg
Post by tonreg »
hi i can not open a arena5 composition in arena6 . Have other the same problem. Thanks Tonreg
francoe
Re: Arena6 composition not loading
Post by francoe »
Resolume wrote:
Why can't I load my Res 4 or 5 compositions?
It's still a work in progress. In the final release, you'll be able to import all your old comps. Right now, let's focus on what's new instead of what's old!
pfelberg
Post by pfelberg »
Hello.
Yes, still unable to load previous R5 compositions. They show up with "0" decks available.
Also, why would Resolume, by default, look after my compositions and save them in my "one drive". meaning in he cloud?
You should be able to open your R5 comps now so make sure you've updated to the latest version.
pfelberg
Post by pfelberg »
Unregistered, uninstalled all previous installations.
Downloaded the latest version and installed.
Registered.
All that before writing the first post. ; )
pfelberg wrote:Also, why would Resolume, by default, look after my compositions and save them in my "one drive". meaning in he cloud?
Your Documents folder is probably linked to OneDrive.
pfelberg wrote:Unregistered, uninstalled all previous installations.
Registered.
Could you check the build number in the About page? (Arena/Avenue menu)
