I'm testing the beta 3 and I love there is a built in text generator. But I am missing some functionality from the old text generators coming as quartz composer comps. In the qc comps there was an option to input multiple lines of text and then output them one after the other and setting the line change speed. With a bit of modification in QuartzComposer you could add the same functionality for the font names and generate a really cool text effect with jumping font styles.
It would be really good to have these options again in the new R6. Because of the abandoning of QuartzComposer comps in R6 the old qc-files can't be used anymore...
Best regards
Florian
						R6 text generator
Re: R6 text generator
The Text animator source and effect in Resolume 6 is very powerful.
Enable animation, set range to Line and with the opacity animated you'll be able to show the text one line at a time.
You can set a custom envelope to the opacity parameter, so you can even control the curve of the opacity.
Hi Zoltán,
thanks for the reply. Yes I know that the tool is really more powerful than the old one and I like it a lot, but with the animate line option the text lines show up one below the other. What I would like to have is that the single lines show up at the same position just one after the other. Like a sequence of lines.
Best regards
Best regards
Maybe make separate clips and use Auto pilot?
Yes, autopilot could be an option but the QC text clips were lot easier to use.
Regards
						Regards
