Hello,
I'm a newbie in video mapping and i want to start doing some things. I was loocking for wall desconstruction effects but i don't found anything, someone can send me a tutorial like this https://www.youtube.com/watch?v=1CFdRL3ghaQ or how can i do, in wich software?
Thank you for your time.
Tutorial to do wall desconstruction vj footage
Re: Tutorial to do wall desconstruction vj footage
Limeart group or search C4D fracture dynamics.
Thank you.. You advise in general some tutorials for a newbie?
My recommendation to you is to learn Adobe After Effect. Most visuals you’d want to create for this type of work will be done in after effects.
Also, with the new version of Resolume supporting NDI, take a look at the NewTek creative cloud NDI plugin which will let you stream after effects live into Resolume.
As Oaktown mentioned, getting basic understanding of AE would be a good first step. This video shows how you could take content like what you've linked to in your original post for deconstruction effects. It helped me wrap my head around it when I first started. This effect is more convincing when done in Cinema 4D on a model with a photo texture.
https://www.youtube.com/watch?v=4ykQLKOYqko
Thank's for your tips..
I have a question, i want to make a test in a facade, i already did an effect in cinema 4d of a deconstruction and what i have to do to project on the facade and to give the effect? I have to render in a special mode?
Thank you
Thank you
One more question, if i do a sequence with several effects, i have to put everything in a video or i have to put the effect separated? Thank you, i have to do some effects for a school project and i'm a newbie.
If your content is all timecoded in AE, all you have to do is export a DXV3 file with alpha as needed. Then you can break it down into multiple clips in Arena by adjusting I and O markers in the timeline.gesp wrote:I have a question, i want to make a test in a facade, i already did an effect in cinema 4d of a deconstruction and what i have to do to project on the facade and to give the effect? I have to render in a special mode?
Thank you
If you have multiple sections, it might be a good idea to render one clip of each section.One more question, if i do a sequence with several effects, i have to put everything in a video or i have to put the effect separated? Thank you, i have to do some effects for a school project and i'm a newbie.
As a note, Arena 6 supports NDI so you might want to try the NewTek creative cloud NDI plugin to test your content before you render.
Also, if you have complex mapping, you might want to take a look at the ability to export your screen/slice mapping as SVG files.
Explain me something, when i have objects in my effects with black color, if i export in alpha with dxv3 it makes my effect white. What i have to do can you help me? I have to export with rgb+alpha with dxv3 codec?If your content is all timecoded in AE, all you have to do is export a DXV3 file with alpha as needed. Then you can break it down into multiple clips in Arena by adjusting I and O markers in the timeline.
Thanks for your time
