Searching Glow/Bloom & LensBlur FFGL FX
Hey there,
I am searching for a Glow/Bloom fx which is compatible with R6. Anyone? ;)
Best wishes
EDIT:
And a way to do or simulate a corner lens blur :roll:
Re: Searching Glow/Bloom & LensBlur FFGL FX
anyone?
Online
Not external effects, but...
corner lens blur:
layers from the top:
5. masking layer, masking one layer below, a white solid color clip with a vignette effect (w BlackBG On ) and an InvertRGB effect
4. blur effect clip
3-1. content
Glow/bloom:
drop a blur effect, set the effect opacity to 50% set effect blend to Luma Is Alpha.
Or for better results, drop a levels effect to a clip slot, and drop a blur onto this clip, and set the layer's blend to 50% luma is alpha. Adjust Levels effect so image has more contrast.
......sweet....thanks Zoltan!
Will try it...when i am in front of the computer.
Best wishes
Perfect! Solves all my first world problems! ;) Thanks again!
