Saw effect in Advanced mode
stefobosso
Post by stefobosso »
I create mapping project and used Advanced mode for maps and mask! BUT! (((
Saw effect in Advanced mode! (oblique forms and lines)
How can i get smooth lines ?
Daniel
Re: Saw effect in Advanced mode
Post by Daniel »
Hey Stefobosso,
These edges are there sadly to stay for now. In order to remove such edges, we would require a system called anti-aliasing. Sadly such system is currently too much of a bottleneck for Resolume.
If you want to make the effect of edges smoother, than the only option at the moment is doubling the composition size and double the size of the footage by scaling it. Than the aliasing would be less prominent.
He2neg
Post by He2neg »
A way to challenge this Problem without touching resolume is to set up your projector correctly at first. Get it as parallel as you can and then mask it.
~Berlin~
francoe
Post by francoe »
Joris, I undestand pictures are from a projected area, not the output panel.
I'll remark 'less prominent' cause, think even antialliasing will have not so much improvement if you are feeding a low resolution dcp. Low native resolution projectors broke any diagonal lines.
I think you mean Daniel :)
drazkers
Post by drazkers »
You are everyone red Joris. It is your forum curse.
I am all that is Resolume. Without me, there is no coffee.
