Adding a slice to Slice Transform effect with Mask scaling incorrectly shows orientation for slice | v6.0.0
subpixel
Post by subpixel »
When the Slice Transform effect has scaling set to Mask, the slice orientation options are hidden. If you add another slice to the Slices collection, the new slice appears with the orientation options shown.
Re: Adding a slice to Slice Transform effect with Mask scaling incorrectly shows orientation for slice | v6.0.0
Thanks for reporting, I created a ticket (#10191)
