OK, I started Resolume & loaded a deck. Then I went to screen setup and set the primary to fullscreen. (I have two monitors, but for a specific application I want to run only one screen).
Got a white screen. Used Alt-Tab to find the Resolume output window, which ran fine. I could cue up video clips, no problem.
Now, how can I switch back to seeing the user interface?
I was able to Alt-F4 to quit, though that gave me a funky error message on the way out.
What I want to do is this - I have a webcam on top of a large TV, I want to run that into Resolume, apply effects, and play it back full screen. The computer connected to the TV only has a single video output, so I want to set up the decks and effects and then switch to fullscreen.
How on Earth do you use Resolume with one screen?
- gpvillamil
- gpvillamil
- gpvillamil
This is not really working for me. The preview mode (user interface) works fine. However, setting the main monitor to fullscreen just leads to a white screen. Ctrl-enter works OK, however after going to fullscreen clips won't play. Decks will load fine, but selecting a clip just leads to a white screen in the preview window.
Resolume 2.2
Win XP SP2
Shuttle ST61G4, Pentium 4 @ 3.2Ghz
ATI Radeon 9600 SE
Resolume 2.2
Win XP SP2
ATI Radeon 9600 SE
