Hello, someone knows if in Resolume 5 like when a clip ends I can with the autopilot, give the order for the next clip to play, could it when a clip is finished giving the order to play ALL THE CONTENT OF THE NEXT COLUMN ???
Million of thanks
auto pilot column
Re: auto pilot column
No, but you use alpha clips that have the exact same duration as your main clip using the autopilot to trigger the next column. Keep in mind that if you need a next clip even if you don't have anything in the column in order for the autopilot to work.
Yep, good trick. Thanks a lot.
Sadly after the 20th or so repetition clips are out of sync ... we really need a column autopilot!
You can use an external controller (artnet, midi, osc) to trigger columns at specific times. With a bit of tinkering you can usually run the external trigger software on the same pc!
