I have a problem with Arena 6. On 5 i used the DMX shortcuts to change the values of effects in individual clips. However now the shortcuts will only act on a clip (or layer) that is selected using the mouse. I have several clips in a column that need to be changed with the same channel.
Was there a change in 6 or is this a bug? If it was a change how am i meant to do this now?
						Arena 6 DMX shortcuts only act on a selected clip
				haydendonald
Re: Arena 6 DMX shortcuts only act on a selected clip
Can you change your "target" to "this clip" under your DMX shortcuts?
				haydendonald
Yeah, i found that after i posted the question. Is there a default setting that can be set? If not can this please be a feature.
