Ableton -> OSC -> Resolume doesn't seem to be working?
Willieev
Post by Willieev »
Hi all
In pretty serious need of help here. I have a live set that relies heavily on my ability to control Ableton and Resolume using a Max patch that send's OSC to Resolume (Avenue). Just updated and, although Resolume shows it's receiving osc signals, it no longer responds (i.e. Resolume Dispatcher plugin no longer syncs, start/stops, or controls bpm in Reslome). Attaching pic that hopefully helps to illustrate what I mean. ANY help would be greatly appreacited as my next gig is on the 30th.
Secondary question: If there's no solution and I'm pretty much out of luck here, would anyone have any suggestions?
Tertiary question: I've heard that Link is built into the new version. If so, where would I find it?
My apologies if these are terrible questions.
drazkers
Re: Ableton -> OSC -> Resolume doesn't seem to be working?
Post by drazkers »
You just need to change the OSC addresses the max patch sends to. R6 has different Values then R5
Atmoss
Post by Atmoss »
Thanks, I noticed the same thing. Could you be specific about the OSC address / values? An example would be awesome. Peace
have a look at this thread:
viewtopic.php?f=12&t=15091
Atmoss
Post by Atmoss »
Spot on, thank you so much!
Willieev
Post by Willieev »
Ah okay thanks!!!
