Duplicating resolume on another computer
Ravage
Post by Ravage »
Good Afternoon,
I am currently upgrading from arena 5 to 6. I am trying to take my setup for a show from 5 to 6 keeping all the setting for video screens and everything the same, BUT I would also like to make a complete backup of everything so I can transfer it to another computer as a backup system incase of a problem.
Is there a simple way to make this happen so I dont have to reset up everything on the new system?
Thanks for the help.
Re: Duplicating resolume on another computer
You can simply copy your Documents/Resolume... folders to the duplicate.
If you keep the folder structure and folder names for the footages on the duplicate the same,
then opening a composition should work without you needing to reconnect the files in your compositions.
