I am very keen on using resolume for a project, but have 1 problem that I can’t find a solution to.
If I have a number of clips on a layer, and a transition time set, when I select a new clip to transition to, playback stutters on the currently playing clip.
Other media servers address this by being able to load the first second of video or so of all clips,that are going to be used in a continuous sequence , into buffers but I cant see a feature to do this, or a work around.
Any pointers?
Pre loading
Re: Pre loading
m.2 drives do a great job handling this. Traditional drives will always cause this with modern resolutions.
In large corporates I actually have multiple ssds and m.2s. Each cue follows to a different drive.
Re: Pre loading
Choosing fast SSDs for media storage is essential these days.
If you want to have the best performance use files with DXV codec.
Starting to decode a H264 for example takes time, if you don't play the H264 from the start you have to seek to a position and if that position doesn't happen to be a keyframe, to get the current frame you have to seek to the previous keyframe, decode, all the frames in between to get your actual frame texture. This takes time and processing power.
With DXV you can just jump to the position and decode.
In media servers that are timeline based, and you don't jump from one point to the other during normal use, you can estimate when a clip begins to play. Pre buffering in a VJ application where you can have as many decks as you want and virtually as many clips as you want, and you could launch any clip at any time, you'd have to keep a buffer for all the files decoded in memory.
Re: Pre loading
Same here, we use fast professional grade SSD and m.2 drives on all our servers and I don't seem to have any issues transitioning between clips. As a note, I use DXV3 codec for every video clip.
@ micpool, are you using a lot of stills in your decks?
Re: Pre loading
Regarding H264. You can encode with option "keyframe every 1 frame", then there is no problems with keyframes.
Re: Pre loading
Thanks for your replies. I am using SSDs. I'll try DXV3 codec.
I realise preloading entire decks would be problematic My suggestion was more that individual clips could be manually preloaded into the buffer if necessary using a right click option or OSC message. So if you had 2 4K clips with lots of motion that needed to crossfade you could preload the beginnings of each cue into buffers.
Mic
Mic
residenthamster
Re: Pre loading
So perhaps like a checkbox in the clip properties to Preload Clip Into RAM Buffer so Resolume will prioritize those clips?micpool wrote:Thanks for your replies. I am using SSDs. I'll try DXV3 codec.
Mic
