Hi !
Ive been using waveclock on win10 x64 with resolume 6 and it works great , only one function doesnt do what i expect.
Waveclock has a silence detector , so if the volume drops under a treshold, it send a silence signal to the resolume midi clock in.
Only , if i use this function , it will kill all clips on all layers leaving me all black screens.
Is there a way to change this for example to a main opacity blackout , or a bpm sync pauze and start going again ?
Ideas toughts ?
Thanks !
Waveclock
Re: Waveclock
They make Waveclock for Windows?
Re: Waveclock
Not really .... you just got to know people :p
Re: Waveclock
Sounds like you should be talking with these people you speak of, since they hold all the answers.Grimm90 wrote:Not really .... you just got to know people :p
How is this clearing clips? Midi? Osc?
Re: Waveclock
Midi
there is a treshold for the silence function .
They say it works fine in other vj software , it's how resolume handles that signal what messes up my setup :s
Ill see to install a midi monitor and see whats the data like , maybe it gets us more far ?
Midiox i suppose to monitor ?
Cheers man would be cool to get this sorted , maybe i can hook you up with the .exe version .
Except for this it works flawlessly honestly on windows 10 x64, i even don't get it why they don't release it
