I want to loop a live video capture that is in sync with ableton’s looper. Could you please help me understand how to do this or if this is possible now?
In Live, i can use the looper device to capture and loop an audio source. I want to loop the video along with the audio, so that i have an in-sync video and audio loop. Is there any way that i can use resolume or some other software with the Ableton looper to sync up with the looper and loop video along with the audio?
For example, I hit a midi button that starts both the video and audio loop. I play a drum riff for 5 seconds, during which Ableton captures live audio and Resolume captures live video. When i hit the midi button again, the audio will replay in Ableton on loop. The video will replay in the Resolume clip as a loop.
I’m thinking that it would create a new clip in resolume for each loop, and that i could loop multiple layers of audio loops and have multiple clips of video loops for each audio loop in resolume. But i’m open to whatever solution that can make this work and figure its probably easier to focus on just one loop first than multiple layers of loops.
Does that make sense? Is that possible to do now?
Thanks, Dan
