Arena 6 - Audio Playing Too Fast
Riffman123
Post by Riffman123 »
Hi
When I load an audio clip into Arena 6 it plays way too fast in Timeline mode. If I switch to BPM mode it still plays a little too fast.
In Arean 5 if I loaded an audio clip in Timeline mode it played perfectly at its native tempo.
Any ideas on how I can fix the problem?
Cheers.
Re: Arena 6 - Audio Playing Too Fast
Adjust your audio buffer in the preference menu.
Riffman123
Thanks for the suggestion. I tried maximising the audio buffer but it makes no difference and it still plays much too fast.
Create a new composition, and check if your file plays fast too.
If it does not, then you probably have the composition speed slider turned up.
Right click on it and you should be back to normal speed.
Riffman123
Thank you Zoltán, that solved the problem. I think the issue was caused by importing an Arena 5 composition into Arena 6. The video was fine but the audio was too fast. However, if I create a new composition in Arena 6 then the audio is fine.
Thank you once again.
