Arena 6 Crash on start/Black output
TaJ@TLP
Post by TaJ@TLP »
Hey everyone,
First off thanks for your time. I recently had upgraded to 6.0.1 and from the initial download things ran smooth. I played around with setting up my MKII and loaded a comp I had previously created in 5.1.4 with no issues. I opened my output, but every time I tried to load a clip it would only display a black screen.
I sifted through the forums and attempted to troubleshoot from previous solved posts. After updating my drivers and configuring my nVidia control panel I attempted to re-open 6.0.1 multiple times only to encounter one of two things each time:
A warning stating Resolume Arena has stopped working and windows will notify me if they find a solution.
or
The load screen pops up and just sits there. When you hover over the screen it simply shows and load wheel. When this occurs Resolume is found in my background processes of the task manager.
To further test what may be wrong I opened up 5.1.4 with no issue, loaded the same composition, and displayed it on my output without any problem.
I then went for a reinstall of 6.0.1, it then opened up once again flawlessly. I loaded one of the example clips and it appeared in the output monitor. I then accidentally clicked the wrong display, attempted to CTRL+Shift+D out of the display, and crashed.
Now once again 6.0.1 is doing one of the two issues again over and over. Any help will be received with extreme gratitude.
Model: ASUS ROG g752VL
OS: Windows 10 Home
Graphics Card: nVidia GeForce GTX 965M
RAM: 44 GB
Processor: i7-6700HQ
Please let me know if there is any further info that would be helpful.
Thank you,
TaJ
