R 6.0.2 full screen output not working! in high sierra
clanbalache
Post by clanbalache »
the full screen output send the resolume output to main screen not the projector connected when select output display 2 ( projector is ok and working well with other apps, syphon output is working good too)
high sierra 10.13.2
nvidia gt geforce 650m with cuda driver ( last ones ) but using internal osx drivers ( tested the same problem with both drivers )
on madmapper fullscreen output works without problem
Re: R 6.0.2 full screen output not working! in high sierra
I looked at your crash log and it actually crashes in the Nvidia driver.
You shouldn't need any additional drivers on OSX to use your gt650m.
Try to uninstall the cuda driver and check if that solves the issue.
clanbalache
i'm using internal osx nvidia drivers instead of cuda,
the output work well in madmapper, but no in resolume
in R6, when I try "Identify Display" it show number 2 in my main monitor instead the external projector ( connected with hdmi )
