I've searched and can see that this has been discussed before. Usually around New Year.
I have been using Qlab for the past couple of years to trigger clips, but...
I was wondering if you kind people would consider adding the trigger "System Time" which would work for clips or columns.
As a further option, perhaps, the option to trigger at Intervals with Duration.
Example, Trigger the clip every 5 minutes for 1 minute or for duration of clip.
Thank you for your consideration.
Ross
