Hello Joris,
I do get the analogy but is there still any way to recall which preset was used/saved with a clip?
For instance: I save Clip A in layer 1, column 1 with effect x and preset y
How can I in Arena 6 see that preset y was saved with that clip in layer 1, column 1?
In the new situation I have to toggle and trigger every possible preset (a-z) to find out with one was used.
I do understand that the moment you change and save a preset it will not be updated in the other clips but I have a workflow in which I hardly ever overwrite a preset but save it under a different name with increasing version numbers. This way the continuity of preset settings is guaranteed.
But then again I also understand that the design choices you made probably make it impossible to rollback to the former Arena 5 situation and that we have to go with the (amazing) new flow.
