R6.0.2 Text Block Error: changing Anchor XY affect other layers clips positions
clanbalache
Post by clanbalache »
In R6, putting several text blocks effect in one layer, when each text block has a different anchor x,y , and the autopilot in the layer is foward, then, the clips running in other layers are affected too in his position xy
( trying to make a simple video lyrics video )
Re: R6.0.2 Text Block Error: changing Anchor XY affect other layers clips positions
Yes, the text block Effect is basically a video router that has the effect on it, so any changes you make to the anchor, will offset the input texture too.
Look for the Text Block Source in Sources panel, if you only want to display text, and don't need an input texture for it.
