I currently have Arena 6.0.3 installed on two 2017 Macbook Pro with AMD Radeon Pro 560 and one NUC with Nvidia 1080GTX and I've been having issues opening Arena on one of the MBP where it crashes during the startup,
I have gone through all the various steps to fix the problem (trash config file, reinstall 6.0.3 and roll back to older version) but I still can't open Arena. I'm attaching the log file and the screenshot that I can take when I'm able to hang the process (it usually just crashes). Arena 6.0.3 opens fine on the same computer if I switch users.
Arena 6.0.3 crash on restart
- Attachments
- Resolume Arena 6 log.txt.zip
- (3.58 KiB) Downloaded 784 times
Re: Arena 6.0.3 crash on restart
The log file stops at Creating the Opengl Contexts, which may not be the last thing Resolume does.
Have tried to rename the whole Resolume Arena 6 folder in Documents?
If you can get it to start this way, please send us the whole folder zipped, and don't forget to sent the bugsplat report.
(The recordings are not needed to keep the zip small)
You should also get a system notification of the crash, and a crash log created in /Users/yourUser/Library/Logs/DiagnosticReports this file could also give some insight of what happens.
I have the same problem when some other software is using the computer's usb audio card.
Sometimes when rendering a video through "Adobe Encore CC" the video drops the FPS, and sometimes Arena6. Rendering directly through AfterEffects, this never happened.
Bruno Vita Pintucci / bruno@vita.art.br / www.vita.art.br
#VITAartBR | São Paulo - SP | Florianópolis - SC | BRAZIL
VeeJaying | Stage Design | Video Mapping | 3D Motion Graphics
www.facebook.com/vita.art.br www.instagram.com/vitaartbr
PLease help! Im having a similar issue. Resolume 6 simply will not even boot. Keeps getting stuck in "Not Responding". Ive clean deleted, reinstalled all versions, cleared document folders, and im not experimenting with legacy video card drivers. Nvidia GTX1080. MSI laptop, and yes I have already deleted Nehimk. WHAT IS GOING ON!!! PLEASE HELP!!!
So one one Windows machine -
- We deleted all project documents in the folder. It then booted V6 fine.
On the second machine:
- We made a visitor user account, and it booted, BUT the 'Arena 6' welcome dialogue will not go away now, even when minimizing.
Still trying to figure out the inconsistency. Not sure what caused this in the first place considering that a month ago our machines ran fine. Just booted up this weekend and it's doing this.
Thanks -
Thanks -
If you're having startup problems which are not resolved by deleting the Documents folder, it's best to drop us a line via mail@resolume.com. You're probably experiencing something hardware or setup specific which we cannot resolve quickly on the forum.
