APC Mini
- rawdesigns
APC Mini
I just got an APC mini and wanted to know how I can switch channels when I midi map?
Re: APC Mini
Switch Channels? As in? Could you give an example what you are trying to achieve?
- rawdesigns
Re: APC Mini
Not sure how to explain. Basically make different pages I can flip through on the controller. So example let’s say I have a fader that does solid white effect if I midi map that same fader on a different channe and let’s say it controls layer opacity, can I toggle through the midi map channels?
Re: APC Mini
That isn't really possible with Resolume natively. I suggest you take a look at Bomes Midi Translator. I've seen users achieving what you want with that program and then those signals are being sent to Resolume.rawdesigns wrote:Not sure how to explain. Basically make different pages I can flip through on the controller. So example let’s say I have a fader that does solid white effect if I midi map that same fader on a different channe and let’s say it controls layer opacity, can I toggle through the midi map channels?
Re: APC Mini
Can confirm it works in Bomes with rules. You can even change colours for pages.
