BlackMagic Decklink 4k Extreme
ddgarcia
Post by ddgarcia »
Hi there!
Recently I bought a decklink Extreme 4k Capture Card.
I have a question regarding it but i'm not sure if it is a limitation from Resolume or the capture card itself.
This card includes multiple inputs ( 2x SDI and also HDMI)
If all of the inputs are connected , i mean if you getting like 3 signals from different sources, can you change them directly on resolume? Or the capture card only supports one at a time?(maybe it's that but so why didn't they made only one input?)
I don't want to simultaneously view all the inputs, i mean, i don't mind if you turn sdi input off to see hdmi input, but is that changeble on resolume?
There must be a explation here that's im missing for sure!
Thanks for the attention,
André
