Install Path
Install Path
Does R6 have to be installed on C: ?
Trying to install on a different drive (ssd internal) since the clients C: OS isn't a ssd, but there is no path option.
richddt
Re: Install Path
Post by richddt »
Bump! Same question - I want to install everything on the D drive instead of the tiny system SSD on this Windows machine.
Re: Install Path
Installing Resolume on other than the boot drive is not officially supported currently.
You can move the program folder once installed manually, I think that should work fine.
The documents folder should work by creating a Junction or Symbollic link to your file system to the D: drive.
