Edge Blend does not work with Stacked Projectors
jcmatos
Post by jcmatos »
Hello! We have been facing a few issues.
My setup generally uses stacked projectors in order to increase luminance, but when edge blending stacked projectors its always only possible to edge blend 2 of them.
The other stacking projectors edge blend always appears in the incorrect place (not where they are overlaying with the other 2 projectors). :cry:
Normally I am forced to use a mask to make a pixel razor sharp cut where the projectors meet (with the 2 ones Resolume doesn't edge blend). :roll:
Is this possible to fix?
I believe an easy fix to this would be adding Masks with a transparent gradient. So we could create our own edge blends at whatever angle we want, and even better, make video fade at certain points for a better blend with the environment. 8-)
Thank you for the attention! Much love.
Re: Edge Blend does not work with Stacked Projectors
This has been discussed before here: viewtopic.php?f=6&t=13293&p=63791#p63791
jcmatos
Post by jcmatos »
Thank you for directing me to the right place Joris!
