I have run into some difficulty with getting light responses on the pads that I trigger on the controller and mostly work blind when triggering clips. I need to find something that automatically maps out resolume to the controller and is super user friendly. I am not a very technical guy so I dont want to have to install scripts and use confusing midi editors to achieve a workable surface. The amount of buttons and knobs on the ohm is ideal so finding something with a similar pad grid and sliders is essential.
Any advice would be greatly appreciated
