Hello Guys!
First of all, I apology for any error on the text, but I am Portuguese and can write badly something.
Anyway, I need your help, or I will go crazy. I used to use Resolume Arena on Windows XP. I bought a new led Panel and I needed to upgrade the Hardware, so I bought a new Laptop with Windows 10.
The problem is: I put my "old" files on the Laptop with Windows 10, try to install the Quicktime Player, but I cant find a version that works on Windows 10.
I also have installed K-Lite Codecs for the Codecs...
So, the "old" and the new files work very well on Windows XP, but on Windows 10, Resolume cant read any file extension, and a big yellow "x" appears on Thumbnails.
I already reinstall Resolume, K-Lite, QuickTime... But nothing works!
Can someone help me and give me an idea to solve my problem?
Thanks a lot!
R. Arena 5.1.2 Can't Play Files on Windows 10
Netlogin44
