Auto Load Decks at Startup
Synner
Post by Synner »
Hey there - I would like to be able to save a set of decks as a startup preset. I wish to be able to launch the program with the chosen decks already loaded and ready to go.
I plan to build a hardware mixer controller for the software and will not be using a keyboard or mouse when I'm finished.
I would like to be able to boot the computer directly to resolume and begin controlling it with my controller.
This would also require the ability to save a preset for the output display settings too.
This could be an option that could be defeated by holding shift when launching the program thus allowing for the software to start up as normal.
Hope to see it down the road...
Synner
