External FFT on Layer FX not working after update.
francoe
Post by francoe »
As tittle says.
I use to have brightness/contrast, levels, or color filters applied on layers with values animated by external fft.
After update (rv60699) that isn´t working anymore.
For clarify it.
Any filter with opacity value linked to external fft:
On clip - work as expected.
On layer - don't get the sound values (no peaks in the pink graphic's representation).
Any idea?
Re: External FFT on Layer FX not working after update.
Does it work when you play something in the layer?
If it does, then this is because the FFT optimizations we did for 6.0.5.
In 6.0.6 the previewed layer's FFT will be shown animating.
inzieye
Post by inzieye »
Ext FFT doesn't work in group FX, even if something is played in the group.
(R6.0.5)
inzieye wrote:Hi,
(R6.0.5)
Yes, thank you!
That will be fixed in 6.0.6.
francoe
Post by francoe »
Sorry about the delay, I think you allready have an eye on that.
Yes, with playing content fft isn't working on layer filters (is not about preview it).
