Is it possible with OSC to choose a deck with its name instead of it's index?
To select a deck called "Hall of Fate" I tried this synthax:
/composition/decks/Hall of Fate/select 1
But it doesn't work. Of course one can use the number of the deck like this:
/composition/decks/9/select 1
But because I have a lot of decks (one for every song), choosing the deck with its name would be very helpful! I'd like to be able to change the order of the decks without destroying the mapping.
Call deck with OSC string instead of index
Arena 7.2.1; Ableton Live 10.1.18 controlling Arena with OSC; Schenker W507 mobile Workstation: i7-6700 CPU @ 3.4 GHz, 32 GB RAM, 2x m.2 Samsung SSD 960 EVO NVMe, NVIDIA GeForce GTX 1060 6GB GDDR5.
Re: Call deck with OSC string instead of index
I'm having that weird french disease where everything happens twice
viewtopic.php?f=5&t=15135&p=64867&hilit ... ate#p64867
Nice that you read every post, even the double-posts...
Can you help me with this question?
Opening a deck via OSC string is not possible.
no but you can do something with code
Sending a string of "?" to the /composition/decks/X/name address will return its name
So you could iterate through the deck addresses asking resolume for the names. Store the names in an array and then use that as a lookup table to know which deck is in which position, allowing you to load the deck over OSC even if you've inserted or deleted decks from your comp. Obviously you'd have to update your look up table directly before calling the deck to ensure nothing has changed but that shouldn't be too much of an overhead providing you don't have thousands of decks in a comp.
