Input Video via USB
Richard Paula
Input Video via USB
Post by Richard Paula »
Hi all,
i need a low latency SDI-video input for USB 3.1 that work with arena.
Does anybody has worked with an Osprey Video Bridge?
Normally we do this with the TB3-port, but in this case we need all outputs for the projectors.
Any other suggestions?
Thx, RP.
Re: Input Video via USB
I use the Blackmagic Design UltraStudio SDI unit and it works great! Unfortunately it's been discontinued but you can still buy it from quite a few vendors.
Quite a few people really like Magwell which a nice selection of USB capture cards: http://www.magewell.com/usb-capture-family. I'm about to get a couple of their USB Capture SDI 4K Plus for an upcoming project.
Richard Paula
Oaktown wrote:I use the Blackmagic Design UltraStudio SDI unit and it works great! Unfortunately it's been discontinued but you can still buy it from quite a few vendors.
Thanks for answer. How is the latency on the Ultra Studio SDI? Do You know the latency for the magwell Input?
I haven't checked in a while but usually you'll get 2-3 frames with the Blackmagic gear. I don't think there is any noticeable difference in latency between my TB2 and USB 3.0 capture units.
Richard Paula
Oaktown wrote:I haven't checked in a while but usually you'll get 2-3 frames with the Blackmagic gear. I don't think there is any noticeable difference in latency between my TB2 and USB 3.0 capture units.
Sounds good. Same here for the thunderbolt devices. I also saw the magewell devices. they sounds also good. Which one do you prefer? Blackmagic or Magewell?
A lot of our current stock is currently Blackmagic Design gear but they don't carry good USB 3.0 capture devices anymore so I'm probably going to start a Magewell drawer at the warehouse!
Warspite
Post by Warspite »
I am happy with AJA U-Tap, in Resolume 6 delay is small, it uses common USB TypeB connection and full size hdmi and sdi.
