Resolume starting without a visible window
Dmitriy
Post by Dmitriy »
Hello. The GS73VR 7RF notebook is purchased for use with Resolume Arena 5.0.4. Operating system Windows 10 home single language x64. UWFI American Megatrends 2017 v2.18.1263. Resolume starting without a visible window, but the process is in the taskmanager. Running in compatibility mode with previous versions of the operating system does not solve the problem. The version of Resolume Arena 6.0.6 is normal starts. Need v 5.0.4. What can I advise to solve the problem?
Dmitriy
Re: Resolume starting without a visible window
Post by Dmitriy »
Laptop manufacturer is MSI.
Do you have Teamviewer installed?
Please send us your log file, on win10 it's in C:\Users\[username]\AppData\Roaming\Resolume Arena
Dmitriy
Post by Dmitriy »
The log file is not created by the specified path. I can provide remote access to TW13. Are you ready to connect?
Dmitriy
Post by Dmitriy »
do not create initial presets settings that should be located in my documents
He2neg
Post by He2neg »
Dmitriy wrote:Hello. The GS73VR 7RF notebook is purchased for use with Resolume Arena 5.0.4.
Do you need to use this Version? There is a updated version of R5.
You may try this.
~Berlin~
Dmitriy
Post by Dmitriy »
Installed version 5.1.4. The result is the same. The program window is not visible. In the program manager of the program is visible. Log file is not created.
I ask for help!
Thank you!
Please try to uninstall Nahimic and try again.
edit: this solved the issue for Dimitriy.
Dmitriy
Post by Dmitriy »
Yes! Yes!
Thank you so much!
Everything works correctly!
