audio glitch @ end of playback
mikimoto
Post by mikimoto »
Yo,
I am using resolume arena 6.0.6 for video + audio playout. Videoplayback is fine - no problems with av sync.
But:
When playing an av clip or even audio only i get a audio glitch ( aka "Knackser") at the end of the clip.
The original audio files sound & look okay/correct.
I tried changing the sample rate (44.1kHz/48kHz) as well as buffer size. no effect.
This happens when using an external audio interface as well as when using the internal soundcard.
Any ideas?
Win10 | i7 3630QM @ 2.40GHz | 16 GB RAM | GTX 675M | Samsung SSD 850 EVO 1TB (Media) - Crucial/Micron RealSSD m4 (OS) | ext. AudioInterface Sonible ML:1
Re: audio glitch @ end of playback
Does it happen with all your AV clips, or just a few?
Do you have any audio effects on these clips/layers?
