DMX triggering clips with linked intensity
nightryder666
Post by nightryder666 »
Hi All!
I use Resolume 6 for theatre shows with with Eos Nomad and MA2OnPC.
What I am trying to do is to map each clip in Resolume to a dmx address that is controllable from the lighting console via artnet.
This currently works, however it merely triggers the clip to appear.
What I want is for Resolume to also make the clip opacity linked to the channel intensity on the Lighting console.
This way I could program fade in/out times for each clip. As I fade up a dimmer channel on the console, it would fade in the 'clip channel' in Resolume.
Obviously linking to the layer opacity can cause issues as it can't take multiple addresses.
It also seems to operate on a LTP basis if you bring up multiple channels on the console at the same time.
What has everyone else done in this situation?
Josh
Empyfree
Re: DMX triggering clips with linked intensity
Post by Empyfree »
Map to the clips opacity instead.
