Additional Features To Current FX
I know you guys have priorities, Just wanted to throw these idea's in the pot for you guys to consider and possible roll out in future releases, when time permits.
Crop - Can we add a feather or blur option to this FX so it isn't a hard line when cropping.
Example: Layer 1 has original content, Layer 2 is a Layer Router with a large stack of FX with Crop being at the bottom of that list. Trying to add that FX stack to a certain part of the the original content, then blend Layer 1 back in so the FX's are added on top. With a Crop Blur, this will make the blend from the original content going into the Effected FX portion of the content less drastic and noticeable.
Keystone - Same additions as Crop ^
Sparkles - Can you add a Color Picker for the Color parameter for this FX? For me, I'm trying to just get white particles overlayed on-top of my content. Right now I'm struggling and still trying to find a solution for this. I tried a B&W Blend mode set to 50%, or adding saturation to it, but this makes the content B&W as well, and not what I'm really going for.
Thanks for the consideration :)
Re: Additional Features To Current FX
Could I also add the following features to this list:
Vignette - Can we make a Mask version of this like you did with Crop, or make a Mask checkbox, that will invert the Vignette to show the outsides of the clip and darken the insides?
I was thinking about having a Video router above a clip with sucker turned on to about 90%, then adding this masked Vignette FX so when played with the original clip, It would have a nice circle around the clip playing in warp speed and the center still playing the regular clip, and I could then have a nice circle I could feather in and out to make the edges nice and gradual .
Hope that made sense?
